Hello!! Greetings to those who read !! I escape to see if someone takes pity and explains where the hell should be the thermostat (or thermosotatic valve) in a Ford Orion, Audi 1.8 Motor Motor Motor Model '95? Thank you!!!
In the lower hose of the radiator you will see on the engine side the aluminum connector have two bolts that you can take with a key of 10 inside is the thermostat.
