My Kymco Venox 250i starts and stops
10 years 11 months before #46776 by manual-mecanica
My Kymco Venox 250i starts and stands out by Manual-Mecanica
Hello, I am writing to you in case someone has an idea of ​​what my fault can be, it is that I am looking in forums and I am made a mess, I have a Kymco Venox 250i of 2007 and what happens to it is that it starts and soon it stops and does not start again until now a good time, to see if someone knows about this, a greeting and thank you very much beforehand.
10 years 11 months before #46795 by manual-mecanica
Manual-mecanica response on the topic my Kymco Venox 250i starts and stops
Hi Laulau, look to see what he does when he stops, if trying to start the spark plugs, for example, or take out the spark plugs to see if they are wet from gasoline, this to see if it is on or fuel or fuel. You tell us to see. Greetings!!
10 years 11 months before #46828 by manual-mecanica
Hi Ismael, if you check the spark plugs and after starting they do not spark, it takes about one or two minutes to stop and it does not start until the next day, check the light as I saw in a video that explained how to check if it is broken or not and marks well, now I am looking at the CDI but I do not want to spend money if I am not sure that it is, thanks for answering.
10 years 11 months before #46829 by manual-mecanica
It can be a coil problem, when they begin to fail by temperature, they tear you sometimes and sometimes no and in the end they already end up not starting the coil and there is no other left to change is. To see this you will have to measure the resistance of the coil in cold and then when you fail you, to see if you have continuity in this, (if you have not already done it). Well Laulau, you will tell us. Greetings!!
10 years 11 months before #46830 by manual-mecanica
To the coil do you mean the high coil?, is that it has two coils and if it is the ignition the resistance after K will stop, I will measure it again, thanks ismael.
