Suzuki Baleno does not part
11 years 2 months before #45930 by manual-mecanica
Suzuki Baleno does not part published by Manual-Mecanica
Holy to all:
Well I tell you that a few days came a Baleno Suzuki to the workshop for change of button. It is all the arrangements,
but at the time of starting it, we review the setting and everything is bn. crankshaft sensor, fucible, cables and everything that we could approach, at first the spark was lost, only gave contact and when closing but that was already solved, when leaving it through the points of factory all the cylinders were left with 30 comprehecious, and when trying with another Marka I had comprehecious, it was tested with another computer
. in advance: D
11 years 2 months before #45933 by manual-mecanica
Manual-Mecanica response on the Suzuki Baleno
Dear, for what counts it may have a compression problem possibly caused by the discharges of the taes causing a "sealed" evil of the valves ... or a badly torqueted cylinder head.
11 years 2 months before #46019 by manual-mecanica
Thanks friend .. but the baleno is without taques is with rockers .. the other
manages to walk not with the factory points .. we throw it with a party truck .. but when stopping it and throwing it not a new part. The strange thing is that it part and works impeque .. kjajkakj if it serves something I hope someone has an answer that you have complicated with this theme xDD: D
11 years 2 months before #46020 by manual-mecanica
If with the manufacturing tuning you have 30 compression, then something bad you have, it could be that happens a lot in the Suzukis where the camshaft pulley has two channels, that is, it has two positions it could be there, because if you have comprehension outside then there is a synchronization problem, or regulation of the valves, are they regulated?
11 years 2 months before #46026 by manual-mecanica
Well ... here I defend: D
greetings .. well the theme of the craft grimaces that we already checked and the regulation of the valves too .. the vehicle now leaves but you have to give almost medium hr so ​​that it starts -.. but when it parties it works and melts and derrepente pff it stops and
denue It can be that it has proOblemas with the sheet or something like that?
: D aa and thanks to the people who have responded to the help: D
