Hello everyone, Jeisus, what engine does your nissan bring? 2.0 or 2.4? The other thing that consumes approx gives you? Because while those engines are super reliable, their Achilles TALON is the high consumption. Other your pickup can be slowed. The explosions I suppose that by admission they can be due to low fuel pressure, it is poor of gasoline, therefore the power of the engine lows a lot, you have to assault it more than usual, therefore they spend a lot. The other thing is that the distribution has been bad. Finally because they moved the throttle body screw, was it very accelerated? The body and acceleration of these engines are adjusted with multimeter, the TPS (butterfly sensor) must deliver a voltage of approx 0.55 volt with closed butterfly.
