Frio boot problem VW Gol 1.6 2011
11 years 6 months before #44465 by manual-mecanica
Frio Starting Problem VW Gol 1.6 2011 Published by Manual-Mecanica
Greetings to everyone if someone can help me I have a VW goal 1.6 2011 gas that they gave me .. This giving cold ignition problems, when left in long stops .. because when the engine is already hot it starts to the touch I change the filters the filters I check the gas pump etc. The scanner does not throw error and the damn of the agency want to charge 1,000 dollars according to them to solve the problem they caused since after the last With the cold ignition problem I would appreciate your help if someone has had this problem
11 years 6 months before #44468 by manual-mecanica
Manual-Mecanica Response on the subject of Cold Start VW Gol 1.6 2011
Hello mecmoch, for the golf, in the water box (which has been sewn on the right side of cylinder head), it carries two sensors, well, the one that wears four poles in the tab, is the probe that is responsible for determining temperature to the ECU, it is of the type NTC I think, in case you want to check, when it fails, or drown hot, or it goes badly at start You will see that it does not mark temperature in the painting, I think it is its only function, which, the latter has nothing to do with the pod .. I hope I have helped you, greetings !!
