Doubt about Renault 19 Culata
11 years 6 months before - 11 years 6 months before #44310 by manual-mecanica
Doubt about Renault 19 Culata published by Manual-Mecanica
Hello good, I have a renault 19 1.9 diesel, I recently broke the cylinder head and when it is cracked it has no replacement or the replacement does not guarantee that it goes well a long time. My question is, can you put a cylinder head of a Renault 1.9 engine but being this supercharged engine?
Thanks in advance, greetings
Last edition: 11 years 6 months before by .
11 years 6 months before #44340 by manual-mecanica
Manual-Mecanica Answer on the subject Doubt about Culata Renault 19
Hi Alexcarvajal! I doubt that you can put it since the combustion chamber will surely be totally different and therefore will not have a good functioning. Where are you from? If you tell me the motor type of the car, I can locate you a cylinder head here.
11 years 6 months before #44343 by manual-mecanica
Hello, as the partner tells you, it is not compatible, not because of the combustion cameras (because the diesel, the cylinder head does not carry a camera, if it pretends) that I suppose that Angelcomouto refers, so I do not think it is worth it is because of the height, the camshaft that can be dragging at another point ... the height of valves, the collectors ... my advice is that you are patient and put an equal, not to complicate. greetings
11 years 6 months before #44349 by manual-mecanica
True Ismael53, I referred to the Precamara. You are right, there are many elements that can be different. Thanks for the correction. Greetings.
11 years 6 months before #44412 by manual-mecanica
Thanks for your help, I already sent you a private angelcomout
