Hello, look to see what values the thermostat that must be over 89 to 93 degrees, and check that it does not open before that temperature, see that the hot radiator sleeves are hot, both the entrance and the output, also verify that the fan electrovalve is good. Check that the pump works by removing a torn engine ... the habitacle air may not open the control of the heating radiator, but it seems to me that it must be a thing of the thermostat, or that is open, or that it is lower temperature than the standard, look to see to see
