The scanner throws the SGTE Code P1336. CUÑANAL POSITION SYSTEM (CKP) Variation not learned. Someone knows that this code really is due. In general, the vehicle behaves well, but has the check Engine X this code on
Try to look at that sensor to have if it gives correct values, and compare them with the manufacturer manual or the self -driver, if that is enough to change it
Hello everyone, Wal7ter you must perform a procedure describing the manufacturer in which the ECU Motor learns the variations in the CKP signal. (CKP Learn procedure). According to the info that management and other similar cases there is no way to do this without a tech2 or similar scanner. This code occurs when: the battery is disconnected for a long time. Damage to teeth (deformations) in the phonic wheel where the CKP and/or CMP affects. CKP change, CMP, ECU Motor or the full engine. Incorrect synchronization of distribution (CMP retard in the scanner) cordial greetings.
