Citroen address C3 gasoline is hard at the beginning
12 years 6 months before #39151 by manual-mecanica
Very good to all, having if someone has happened or knows the answer of this:
a C3 gasoline, with new battery, started the engine, and the assistid address does not act. After the minutes (more and more) start working and it no longer fails. It happens when you let it cool the car, (from one day to another). I have my question about the possibility that is the alternator that takes time to give the load to the battery, or the module that commands this, he lacks some programming. I hope someone knows what happens to him. Thank you all.
12 years 6 months before #39154 by manual-mecanica
Manual-Mecanica response on the topic Citroen C3 gasoline is hard at the beginning
Check the connectors of the module of the direction -dae-, make sure you have a good contact, lubricates if necessary, ... and perhaps it is blocked, connect and reconnect the fuse to unlock it .... Greetings Comrade.
12 years 6 months before #39158 by manual-mecanica
Thanks I will try it ...
12 years 6 months before #39377 by manual-mecanica
It is already solved !!! The unit had current, both at the entrance and exit and the address pump marked its 12 volts. But although it had current, the bomb was stuck. In other words, if you find this failure, and you note in the steering wheel a feeling of wanting to turn fine and not being able to ... you have to can can can can can can Can the entire direction, since the pump does not sell it loose. (A paston).
12 years 6 months before #39392 by manual-mecanica
Thank you for posting the solution to your problem we will take it into account.
