Grand Vitara Suzuki does not turn
12 years 11 months before #35610 by manual-mecanica
Grand Vitara Suzuki does not turn published by Manual-Mecanica
Hello friends, I have a problem with my Grand Vitara Year 2000 Motor 4L 4x4 Synchronic I can not get spark and the ECU already probate it with another truck and it is good. If anyone knows where I can get the electrical scheme
12 years 11 months before #35612 by manual-mecanica
Manual-Mecanica Response on the Re: Grand Vitara Suzuki does not turn
First you have to check if that Biene with Chevy Star alarm system if it brings them, you have to block the two modules one, under the bowl to dentor and the other is behind the radius or behind the glove compartment took the two cable pacha and it makes a bridge and gives it Starter
12 years 11 months before #35670 by manual-mecanica
If you do not have a spark, try the crankshaft position sensor, or magnet captor is in the queue axis tail in that engine and has a three -legged connector, if the flijometer is fine. To see how nothing.
12 years 11 months before #35673 by manual-mecanica
Translation: Chevy Star is called the temporary lock of ignition for its last 2012 models, the steering wheel is something else, it is what one turns the wheels, in the bikes they are called manubrio, the better the service manual that here is, thank you
6 years 5 months before #53684 by manual-mecanica
Manual-Mecanica response on the subject Grand Vitara Suzuki XL7 does not turn
Good morning friend, I also have a problem with my XL7 year 2004, I turned off, and I don't turn on, it comes to the coils and injectors and the fuel pump, the spark plugs are changed, the fuel changed, but it still does not turn on, it does not have Chevy Star or any alarm, if someone can help me please please
