Consult, what are the divers?
13 years 2 weeks before #34816 by manual-mecanica
Manual-Mecanica response on the Re: query, what are the divers?
Raise hydraulic valves
13 years 2 weeks before #34868 by manual-mecanica
Thank you my friends for your answers and I hope it is enough with a cleaning as it says that four ...
13 years 2 weeks before #34871 by manual-mecanica
: Laugh: "Diver" or lift valves and in Mexico the name is "bumps" and as a recommendation I would tell you that you change the 20W50 oil and you also check the sieve of the oil pump that is not covered, to do this you have to remove the carter or oil storage and remove and clean the sieve because covering does not let the oil rise easily and causes the "button to May the temperature be normal .... I hope it serves you ,,,,, greetings
13 years 2 weeks before - 13 years 2 weeks before #35027 by manual-mecanica
: Woohoo: Hey! Thank you for your comment, I will do what everyone has told me and then commented on the results ... I just bought the packaging to replace them ... :lol:
Latest edition: 13 years 2 weeks before by . Reason: add more words
12 years 11 months before #35851 by manual-mecanica
:( My friends told them that I had a small problem with the couples, of the good was that I found one of the damaged divers and bought its replacement the problem was when it came to put together like every rookie "do not mark the punch in which the camshaft"
