205gti does not start
17 years 3 weeks before #3391 by manual-mecanica
205gti does not start published by Manual-Mecanica
Hello everyone, having told you, the gasoine pump does not go and it is not even for the pump that is tested in addition, there are 2, the reverse is changed and the ignition pill is also It is from 89 pro is catalyzed comes Germany, greetings
17 years 3 weeks before #3394 by manual-mecanica
Manual-Mecanica Response on the Re: 205Gti does not start
Hello, as I pass it in my case with a VW in the ignition system, I do not start from one moment to another the Idge pill (key cylindrode) has a white color connector at the bottom it is the active current to open the key when opening the key when the abas you will send 12v to the distributor cable if the darmarcha there is no constant current is the power pill you can do the test.
17 years 2 weeks before #3402 by manual-mecanica
Looking before the inertial interruptor in the hood and proves all the fuses and sees the connectors
17 years 2 weeks before #3403 by manual-mecanica
correction, not in the hood but inside the vain of the engine
17 years 2 weeks before #3409 by manual-mecanica
I will have to check all the fuses, to the ignition pill I already look and change will have to look if it is the contact of the key I will tell you, greetings and thank you
