Opel Kadett GSI
13 years 2 months before #33407 by manual-mecanica
Opel Kadett GSI published by Manual-Mecanica
Greetings ... I am the proud owner of an Opel Kadett GSI of the '89. I have decided to repair it little by little, with my own means. Although I have downloaded the "workshop manual" of my vehicle on this page, it has not dissipated the ODS doubts that I have. First: although the bulbs are fine, the back light does not work or the rear fog. I think it can be a fuse problem, but I don't understand the electrical scheme. Second: I want to change the front brake pads, but I can't disassemble them. Thank you very much for your help.
13 years 2 months before #33416 by manual-mecanica
Manual-Mecanica Answer on the Re: Opel Kadett GSI
Tonia wrote: Greetings ... I am the proud owner of an Opel Kadett GSI of '89. I have decided to repair it little by little, with my own means. Although I have downloaded the "workshop manual" of my vehicle on this page, it has not dissipated the ODS doubts that I have. First: although the bulbs are fine, the back light does not work or the rear fog. I think it can be a fuse problem, but I don't understand the electrical scheme. Second: I want to change the front brake pads, but I can't disassemble them. Thank you very much for your help.
The back light could be the fuse or switch located in the speed box, on the cover covered by the fusera generally have drawn the effects of each fuse, it is atmosphere to interpret them.
As for the pills, it is simple but it has its details, therefore if you cannot disassemble them it means that you have no experience, I think you should resort to a professional or friend with knowledge for this, lest to save some pesos, provide an accident with consequences for you and for a third party.
11 years 5 months before #44600 by manual-mecanica
Manual-Mecanica Answer on the Opel Kadett GSI
Hello my name is Luis. I don't know if you help you
in CTO to the freb if they are front. First you should sink the piston of the tweezers.
Then take up the present is a steel waiston
later. In the back it has rubber caps which you take them out. And inside are the screws that are of exagonal key or
the measurement would not know how to tell you but it goes between 5 ..... at 8 mm
you sand the disc and the Nuebas pills.
They
in
respective
position .
11 years 5 months before #44603 by manual-mecanica
Hi Tonia, congratulations on your car, that few remain !! You can also count on me, I have a caliber of 92, Tube also Kadett SV, and my Corsita GT NV ... With this I just want to say that I know them a lot, Averias, very few !! .BUEN THE BRAKES THEY HAVE ALREADY EXPLAED YOU OR LESS, TO BE FASTERED TO TAKE THER if there were any pelao cable for some blow parking, etc .. the rest because as the companions have told you. Greetings!!
