Hello. It is a generic code and refers to the O2 sensor circuit (Lamba probe), range/operation, sensor 1 Bank1. Therefore it would be the oxygen sensor before the catalyst. Before you can check it, you should check the installation and connectors, it is also important to verify that there are no leaks in the exhaust system. Greetings
