My Buick Lesabre is unstable in minimal move, I already changed teaching module, verify maf and throtle sensors, and all well .. What notices that the brake sometimes gets hard, will it be empty problem?
It could be the problem of the servo but first I recommend cleaning the body of the admission, and the IAC valve, if it does not bring the body and the electronic accelerator clean, the air filter is checked first.
Thanks for comment apparently the problem is in the gasoline pump, Noe sta delivering the correct pressure, so it loses power, this is the time the engine is not a capitage of generating the necessary emptiness, so the brakes are tough.
