IAC valve
13 years 6 months before #28700 by manual-mecanica
Manual-Mecanica Response on the Re: IAC Valve
By the photo that would not be an iac valve, it looks more like an acceleration body, it is still cleaned but carefully if you spoil it anymore your vehicle.
13 years 6 months before #28736 by manual-mecanica
That faya has your car or because you are looking for the IAC your car is of automaric acceleration is not from chicote and I do not have the TPS is within the acceleration module. Does not clean it is the type of checala and comment. information
13 years 6 months before #28938 by manual-mecanica
I tell you the fault that my Peugeot presents every time I am going to turn it on begins to tremble and turn off, I have to accelerate it several times and stabilize, how much I make these acceleration sounds some explosions this is every time I am going to turn it on. I did injector cleaning and spark plug change, gasoline pump battery, I'm going crazy with these fault. If you can help me. thank you
13 years 6 months before #28941 by manual-mecanica
Greetings Rojasevans, apart from the symptoms when it turns on is with the cold engine, with the hot engine, how is your walk? spend fuel? Have you scanned it? From what you say it seems that an electrical problem of the sensor type points. Sorry for so many questions but it is to be able to give you one diagnosis of possible cause and solution.
13 years 6 months before #28943 by manual-mecanica
Hello friend, those photos for me, are from the acceleration body and if it is convenient to clean it, but more than that it would be good to scan it to see if it presents any fault code and make the basic adjustment with the appropriate equipment. And what you know is that if it is disconnected it is deprogram, it will only be in VW with that type of acceleration bodies. It would be good that they gave you a diagnosis with the scanner first. Hopefully this comment serves you greetings and luck.
