High clutch pedal, but it doesn't skate
13 years 7 months before #28095 by manual-mecanica
Renault symbol, clutch pedal acts high, but does not skate, you can regulate, the mechanism of the autoajustable pedal.
13 years 7 months before #28116 by manual-mecanica
Manual-Mecanica response on the Re: High clutch pedal, but does not skate
hello.
The clutch pedal has a regulation. But it is only distances of pedal routes.
If the clutch already cuts high is fulfilling its useful life and there is nothing more to change it to avoid more expensive failures, you do not stop verifying the piston of the clutch piston for a possible failure in that system.
Good luck and tell us.
13 years 7 months before #28127 by manual-mecanica
The self -regulators cannot be regulated but they sell the piolas with mechanical regulation, of course that if it does not give you little of the clutch kit and it is better to change it
