Hello, I think you have a problem with the identification of the Ralati valve, Mira enters
www.google.com the writer IAC Ford selects search by image and with the images that are sure to surely find a similarity with some piece installed either in the multiple of admission or in the acceleration body since the truth I do not remember where it is installed, once the locality is clean. The holes with a spray (sprinkler) that I used to linked carburetors you would find in any automotive parts store. You also remove the acceleration body and clean the interior with this same liquid, when you are cleaning the acceleration body that the cleaning liquid is touched by the TPS sensor mounted on the acceleration body, be careful also with the packaging both the IAC valve and the acceleration body.
I hope it is useful.
And if the problem continues, do not let it comment.
Mexico,
April 18 08
