Renault R19 1.8rti at low revolutions
13 years 7 months before #27486 by manual-mecanica
Renault R19 1.8rti at low revolutions published by Manual-Mecanica
Good friends ...
I have a problem with my Renault 19, it turns out to change the spark plugs and now it works a few revolutions, is it as if it worked in 3 cylinders, what could it be?
I tell you that it is gasoline, and I do not use CNC ...
I have also noticed that when I put the air it goes down much more and it even seems to want to go out ...
I need help ...
13 years 7 months before #27742 by manual-mecanica
Manual-Mecanica Response on the Renault R19 1.8rti at low revolutions
Although Senso may seem, you consisted if it does not lose pressure for any changed spark plug, or if the spark plug wires make good contact.
