My Clio II of 2002 1.4 D does not start
13 years 7 months before #27462 by manual-mecanica
Mi Clio II of 2002 1.4 D does not start published by Manual-Mecanica
The car comes into contact but flashes a circular red light that had never done it very fast before, I don't know what is due not to start and start with tweezers. I was hit by the starting in case they were glued brushes but nothing and looked at the fuses but nothing. Please if Algien knows something that I tell me thanks a cordial health ...
13 years 7 months before #27469 by manual-mecanica
Manual-Mecanica Response on the Re: My Clio II of 2002 1.4 D does not start
The light that flashes you is from the starting univide
13 years 7 months before #27478 by manual-mecanica
As they wrote before it is a problem with the transponder or module of the key and the sheet, you must lift it to where they review that the ossea is part of the renualt or someone who specializes in plates with transponder so that they change the code
13 years 7 months before #27493 by manual-mecanica
There may have been decoded the plabo without more or run out of battery. Try another plabe to see. If you do not have it there is a starting procedure if this happens, in the Megane workshop manual it is explicated and I think it is the same system. It is giving pulsations to enter a code with the doors closing button.
I hope it serves you.
13 years 7 months before #27495 by manual-mecanica
By the way, if you decide to take it to workshop and tell you that it is the UCH and that it must be replaced by take it to another site and give you different opinion, since they do not usually have been and just encode the plabo. You can also remove the inhibitor of the inhibiting pump.
