Citroen C2 brake drum
13 years 7 months before #27431 by manual-mecanica
Citroen C2 brake drum published by Manual-Mecanica
Hello everyone and thanks beforehand.
I have disassembled the wheel and nut of the bushing that holds the brake drum, but I can't get the drum.
I have read that if some blows to release the shoes, that if a screwdriver through the holes of the wheel screws, etc.
I have removed the handbrake and turn freely.
Surely it has some trick.
I don't know where to look. Let's see if Alguen can lend me a hand.
Thank you.
13 years 7 months before #27441 by manual-mecanica
Manual-Mecanica Response on the Re: Citroen C2 brake drum
hahahaha the drums do not have tricks if you have to hit the strong drum without fear, so that the oxide breaks and then you have two screwdrivers one in front of the other, between the drum and the poster luck
