PROBLEMATION EXPEDITION
13 years 7 months before #27354 by manual-mecanica
Expedition problem published by Manual-Mecanica
How such friends of MDM because here bothering them again because I have a problem with an American expedition of 8 cylinders model 2001 The problem is that sometimes fails and marks little and sometimes it works in perfect condition and when it marks the P1131condigo and the gas filter already changed the pump and wash injectors 2 times and nothing
13 years 7 months before #27355 by manual-mecanica
Manual-Mecanica Response on the Re: Problemacon Expedition
This code is due to an anti contamination system, or catalyst, zonda o2
312 284 3960 (Colombia call
13 years 7 months before #28248 by manual-mecanica
I have the same problem, publish the solution please, I'm from Mexico
13 years 7 months before #28256 by manual-mecanica
Something similar happened to me; The code refers to oxygen sensor, in my case I checked them (O2) and they were fine. Check the entire ignition system and find a spark plug with a small crack. Change them all and solve the problem
13 years 7 months before #28260 by manual-mecanica
Thank you very much, indeed the problem is of the spark plugs, I spoke with the plant and the spark plugs that installed cause the fault so they changed the type of spark plug and everything was corrected.
