Estimated:
I ask for help since I have a flat with electronic problem at Hyundai Accent Year 95 Motor 1.5 12 valves.
The vehicle failure is that the damage witness is turned on indicating the following codes, 3211 that indicates a pounding sensor (chopped or detonation sensor) Ultimate Oxygen sensor has changed 2 times and the fault persists. I barely delete the codes and I turn on the engine the 3211 code appears, and after walking it for a while, the other codes are activated.
The vehicle is changed:
spark plugs
of spark
plugs
180 Parejo
Bencina and air filters.
Bencina Precion 2.5 Bar
Cleaning Complete to the
Oxygen Sensor admission.
The pounding sensor was taken from an accent from the same characteristics for test and the equal code appeared, it is not a bad sensor.
Someone has the notion that the vehicle can be done more to solve the problem.
Greetings and thanks ......
Dan
