Problems with Mazda Allegro 1995
13 years 7 months before #27311 by manual-mecanica
Manual-Mecanica Response on the Re: Problems with Mazda Allegro 1995
The MAF sensor is already changing now I stay with a jaloneo when it accelerates to 2 passes ... what can it be?
13 years 7 months before #27312 by manual-mecanica
Check also how your coil package works that can be the cause of your jaloneo
13 years 7 months before #27368 by manual-mecanica
Check how the spark plugs, the injectors are working, measures the resistance of the spark plug cables and the last case if the scheme are manual valves check the calibration
you can have many points to review after this
the time in the distribution band
the pressure of the pump
13 years 7 months before #27391 by manual-mecanica
;) THANKS IS ALREADY READY THANK YOU ALL FOR HELP
GREETING
13 years 7 months before #27410 by manual-mecanica
and that it was serious if you put what the solution of your problem was so that we all find out if it is not much discomfort.
