Smell of gasoline in the room of an escort 1.8
13 years 8 months before #26884 by manual-mecanica
My niece has bought an escort 1.8 (105) and smells a lot to gasoline in the habitaculus. I have made a look at the first view I don't see anything. If someone comes up with something tell me where to continue that I am lost. Thank you
13 years 8 months before #26885 by manual-mecanica
Take out the rear seat and check the orring where the cables enter the pond, most likely it is cut or bite and there escapes the smell
13 years 7 months before #27228 by manual-mecanica
I already checked that rubber and apparently it seems to have anything. They tell me on the other hand that it can be of a sleeve. I will keep looking at if I get it. Thank you so much.
If someone has the workshop book and it can happen to me, it would be appreciated because instead of a car it looks like a grandfather with so many achaches that come out. Thank you.
13 years 7 months before #27244 by manual-mecanica
Czech the flexible of the escape line you want is broken and the smell gets into the abitaculus there, luck
13 years 7 months before #27516 by manual-mecanica
Thanks for the information. I will take a look if there is luck and it is there.
