Peugeot 806 gasoline sometimes stands
13 years 8 months before #26460 by manual-mecanica
Peugeot 806 gasol
How, my consultation is as follows, I have this 806 for a few weeks and I still don't know the ñañas, sometimes it is perfect but only the accelerator is loose to put a march and stop the engine, as an extra comment I tell you that the speedometer is not working well, the needle heads at low speed and only at 80 kph or more stabilizes, it has something to do since I read that I read that I read that I read that I read that I read that I read that I read injection?
A big hug now
13 years 8 months before #26462 by manual-mecanica
Manual-Mecanica response on the Re: Peugeot 806 gasoline sometimes stands
Clean the admission body generally they are removed with that cleaning, usually
13 years 8 months before #26464 by manual-mecanica
Thank you Kikeme for your answer, look just started it and all normal in cold, with revolutions of 1100-RPM after it heated low to 800-RPM, did not make the fault I will verify if when it is at normal temperature the problem begins.
All this is as a guidance since I am not a mechanic, but at least I try to inform me for when I do the consultation in a workshop.
Greetings
13 years 8 months before #26988 by manual-mecanica
Possively or incident is caused to devoted to failure not sinal sent hair speed sensor. When or Ingheção não does not receive this sinal correctly, a march-Lenta Fica Instavel (A initialização two self-adaptive depends on the speed of veulular speed) ea função that cuts bicos injectors emtelleração não works correctly (for auxiliary no "freio motor", diminute or level of emissõ Combustivel, or Module of Interference "Distress" Bicos Injections during contempt of EM marks e "Raise-Los" Logo that at speed, which and captured hair sinal do Sensor of speed, fell abaixo of 15 kmh
