Daewoo Matiz starts and stops
13 years 8 months before #26322 by manual-mecanica
Daewoo Matiz starts and stops by Manual-Mecanica
Hello friends of the forum .. to see if you can throw a cable with a problem that I have with a daewoo nuance year 2000 three cylinders starts in cold well and then it stops it anymore there is a spark I forgot the spark plugs ... Thank you for your help
13 years 8 months before #26335 by manual-mecanica
Manual-Mecanica response on the Re: Daewoo Matiz starts and stops
Do you have a way to scan the car ???? Because I beat that the car is drowning, it can be, by: an injector that is not working, an over pressure in the injector rail, due to a malfunction of the injector regulator, pump with pressure, checks the pump pressure and the resistance of the circuit of the injectors, because one thing is that you have a signal in the injectors and another that your injectors are working.
13 years 8 months before #26349 by manual-mecanica
The scanning smells like a problem with the temperature or air problem insufficient both possibilities wet the spark plugs not only the lack of spark
