NOISE FRONT TRAIN IN FORD FIESTA 2006
13 years 9 months before #25979 by manual-mecanica
NOISE FRONT TRAIN IN FORD Fiesta 2006 Published by Manual-Mecanica
When the car is filmed, a pounding is heard in the front transmission ... Reviso but I can't find anything, the spirals and damping just changed ... Can it be the stabilizer bar? ... Thank you.
13 years 9 months before #26014 by manual-mecanica
Manual-Mecanica Response on the Re: Front train noise in Ford Fiesta 2006
I recommend driving on an irregular path to provoke the pounding and when you hear it gently step on the brake pedal, if the noise decreases or disappears it is because it comes from the brake system, in that case you must check the antivibrators of the brake pads in case they are lazy and/or readjust and lubricate (if necessary) the jaws or calipers.
