Please help with a Jeep Cheroque
13 years 9 months before #25895 by manual-mecanica
Please help with a Jeep Cheroque published by Manual-Mecanica
I have a Cheroke the problem is a cold spinal scara is and it works for 10 minutes to oscillate the RPM 300 to 2000 rpm only without accelerating everything was fine to repair the automatic box and spark plug and last He no longer wanted to scratch and what will be the problem, I will appreciate him enough for his help.
13 years 9 months before #25922 by manual-mecanica
Manual-Mecanica Answer on the Re: please help with a Jeep Cheroque
I had a similar problem, check the pump relay
13 years 9 months before #25929 by manual-mecanica
Check the ground connections, especially the motor to the body, and check the battery state since the minimal battery voltage failure makes you work the compystator and the module badly. I have an 1988 and when I start to fail I maintain the electrical system and it is a good time.
