BMV fault
13 years 9 months before #25789 by manual-mecanica
BMV faults published by Manual-Mecanica
I have a BMV brand car (3.20 diesel) and one of the cylinders fails me, I have taken it to the BMV and they say that the gase spit has sneaked into the cylinder and has entered the engine ... is that true? Or they just want to put the hours to open the engine ... all help will be well received,
thank you very much !!!!
13 years 9 months before #25794 by manual-mecanica
Manual-Mecanica Answer on the Re: Farm in BMV
Hi Amariguanao, indeed those engines break by there are, but it is not the gas plate, it is one of the traps that mounts the admission collector for the variable admission. You have to remove the cylinder head and see the damage it did, but when you repair or change the engine you have to disassemble the ones that remain and cancel that system shit that for the only thing that is useful is to break engines. Take it with a little humor that is already done. Salu2 and luck ...
13 years 9 months before #25798 by manual-mecanica
hahahajaj it is true you should get the cylinder head and see what step, you can have rason is not very useful that system hahaha
13 years 9 months before #25801 by manual-mecanica
many thanks for everything !!! I hope that sheet has not done much damage !!!
