Voltage that must mark the battery
13 years 9 months before #25776 by manual-mecanica
Voltage that must mark the battery published by Manual-Mecanica
Hello everyone, my question is what voltage should the battery mark, and the alternator?
And how these data are measured.
Thank you.
13 years 9 months before #25777 by manual-mecanica
Manual-Mecanica Response on the Re: Voltage that must mark the battery
It must mark minimum 14 volts with the engine on
13 years 9 months before #25788 by manual-mecanica
Hello, how are you:
To check the battery, it must be at rest, I mean, without electrical activity as minimum 12h.
Then you measure the voltage with a tester and assuming that each element must have 2.1V, the total voltage would be 12.6v to begin with.
When starting the engine should raise the voltage between 13.5Vy 14.5 depending on the state of the battery.
I advise you to also measure the amperage and know more accurately the state of the battery.
All the best
13 years 9 months before #25797 by manual-mecanica
With a multitester you put positive in battery and the negative of the Batteria negative, you must measure 12.5 OLTS, without taking out the tester, ask someone to start and not to lower to less than 10.5, once starting the engine you must raise the voltage to up to 14.5 and minimum 13.5
