Failure Failures Nissan Platina 2004
13 years 9 months before #25753 by manual-mecanica
Failure Failures Nissan Platina 2004 Published by Manual-Mecanica
Greetings. I want to solve a problem with the braking lights of my Nissan Platina. I already changed all the bulbs of both rear lamps and made changes to all the fuses of the car to see if the problem is solved, but nothing changed, when the brake pedal operates, the lights still do not turn on. It may not be a problem of great importance, but the purpose is to prevent some type of accident for this failure. What do you recommend?
13 years 9 months before #25765 by manual-mecanica
Manual-Mecanica Response On the Re: Failure Failure Lights Nissan Platina 2004
Monsterized Look where the brake pedal is an interruptting, when you step on the pedal, it is released and closes Sircuito and turns on the lights, when you release it Obio passes to the setback and short, it goes with a two cable connector they usually spoil check it, disconnect the connector and you have a bridge between its two legs if you turn on the lights you change it and it is no longer expensive.
