Solisito helps
13 years 9 months before #25708 by manual-mecanica
Solisito Help Published by Manual-Mecanica
A Toyota Pickup 89 Ay spark came to my workshop, I don't have a gasoline injection, I don't have a scanner, I get codes, I get 12 and 14 12 it is rpm If there are revolutions on 14 is a sign Igf no ay signigf my question is if this signal comes out of the ignition module acia the ECU and how do you measure this signal Munchas thanks for so help
13 years 9 months before #25709 by manual-mecanica
Manual-Mecanica Response on the subject Re: Solisito Help
Do you have current in the injectors?
13 years 9 months before #25723 by manual-mecanica
If there is current in the injections, what does not arrive is the pulsation, that is, the computer signal
13 years 9 months before #25725 by manual-mecanica
Rotation sensor test
13 years 9 months before #25727 by manual-mecanica
Thank you Govi, I already check the distributor, it has 3 rapping coils bariable, they give me a good sign, check ECU their positibas and negative feeds and are correct but from the ignition module the signal IgF Asia the Ecu does not come out
