The battery is downloaded
13 years 9 months before #25702 by manual-mecanica
The battery is downloaded by manual-mecanica
Hello, I have a problem and it is that the battery is downloaded very fast and I have also observed that when I boy to put the starter engine I have oc observed that hits the battery and the heater acts Alavez that I start in motion and then hits a low that cannot move
is a 115cv Ford Mondeo of the year 2011
the battery the battery will take me lasting two day
13 years 9 months before #25704 by manual-mecanica
Manual-Mecanica response on the re: the battery is downloaded
Check the electrolyte its level and its status, that is, the density must be on an average of 1.27. Or otherwise try another battery asks your friend. If you present the same symptom, it may be due to a starting failure. But first discard the battery. And if you manage to turn the endothermic engine with the help of an instrument to verify if the load system is properly operating.
13 years 9 months before #25710 by manual-mecanica
Czech with the voltimeter must present you minimum 14 V. And as Maximo 14.7 and Czech with the lights on if your alternator varies a lot. Intempon a lamp between the bat. And the cable if it turns it on intense you have a short, hopefully help you. Good luck you communicate as you are going.
13 years 9 months before #25729 by manual-mecanica
What battery do you have installed? Is it the oil or benzinera mondeo?
