Good evening, what you have to see first is to disconnect the transmission plug (oviously would be canceling the transmission sensors) and if the problem is the envelope sensor, the problem will no longer give you the problem I tell you this just to check it because when the sensors can You caught part of the day and you do not have the problem, then you walk the sensor, because what happens is that the sensor is heated and the fault comes you have to wait for it to cool and when you put the scanner it does not appear to be swimmed because Todabia is not burned, what engine does the 3.1 or 2.2 go, woe anything you let me know, after.
