I apologize not to have written before I had not opened my page due to lack of time, because I saw the coil on the distributor lid and the ignition module is also high energy since these distributors were among the first to produce more than 45,000 volts in the secondary to produce a more intense and effective spark in the cylinders. First change the secondary coil of the secondary. The non -west lid broken if you see any cracks change it, clean the connections between the coil and its food also its land that all this clean and well installed to avoid that you have current leaks and remember to put siliconated fat below the module between its base and the module is essential, I hope that it is not short of your condenser is a square is still side of the quitaln modulus and try it if I do not work.
