HELP SEAT ALHAMBRA 2003, OIL INDICATOR AND YOUR
13 years 9 months before #25116 by manual-mecanica
Good day. I have a problem with my alhambra, I sent her repairing the turbo and the repair consisted of preactically putting a new one, the issue is that after this it has happened to me that the level of refrigerant low and constantly I have been adding more, trying to avoid a heating, the matter is that in hot it does not give signs of liquid leakage, nowhere The catalyst and another thing and things, the issue is that I have only been able to see it dripping liquid in the morning when it is conplepically cold, I could not see exactly where the liquid was leaked but the matter is that it is not emptied drops for a while and then stops doing it. I have already desperate to go around, I would like to know if someone can comment or advise me about it. Thank you
13 years 9 months before #25131 by manual-mecanica
If water falls, leave a path you must follow it to where you can discard some components, because without seeing that we tell you from where it bootes.
13 years 9 months before #25136 by manual-mecanica
Thank you. I will make an early review of this point to inform you.
Greetings!!!
