Hello Jose As you say the marker's precion if it affects the start of an engine since the highest height is lower the oxygen content in a certain mass of air) therefore you will need a greater volume or mass of air to get the air, oxygen, fuel, for a good combustion, for a good combustion, for a good combustion, what does not happen at sea level, for that. ECU reads the indicators of the flow, èste measures temperature, flow and air mass, with these parameters it starts the injection, therefore increases or decreases the injection and can avoid the exesive pollutant pollution, it has and as it is at great height you have a fuel excess in the excess of oxygen that you need so that the combustion is produced by the spark Heat, and because it happens after a long time, it
becomes
