problems with my party
13 years 10 months before #24981 by manual-mecanica
Problems with my party published by Manual-Mecanica
Hello, how are you I have a problem I have a 2002 Ford Fiesta and the connecting rod parties the carte and I lowered it to wear it, you know if you have a pocision the rings and if I can put the same ones a year ago that the engine does it if you can help me
13 years 10 months before #24986 by manual-mecanica
Manual-Mecanica Answer on the Re: Problems with my party
Hi Felix4388
You must do several things: find out why the connecting rod was clogged, -he cylinders to verify wear and know what the rings is related,- verify state of casques and crankshaft stumps especially in the position that suffered the damage, if the butt suffered with the blow that should have given the piston, practically do the whole engine. Luck.
Miguel
13 years 10 months before #25000 by manual-mecanica
It is true what Servi says, you will have to make an adjustment again, but for your response the rings go in an order that is written in the bag where these positions in the piston are with the top or any brand that brings up, and you should never stay the ahasses together in the same Linies usually 1 thumb of difference.
