Daewoo DB 33 engine
13 years 10 months before #24915 by manual-mecanica
Motor Daewoo DB 33 posted by Manual-Mecanica
Hello, how are you all, I have a problem of lack of power with this engine, does anyone have the tuning? thank you so much.
13 years 10 months before #24949 by manual-mecanica
Manual-Mecanica Answer on the Re: Motor Daewoo DB 33
What model of Daewoo we talk about and what year is, as well as its displacement, it is easier for us to search the base of tados than by motor code.
13 years 10 months before #24963 by manual-mecanica
Hi Kikemec, the engine is mounted on a Daewoo self -eleventh, it's diesel, I guess 3.3.Litros. I understand that the engine is Izusu. Would it serve you to do the codes of the injection pump?. thank you so much.
13 years 10 months before #24979 by manual-mecanica
The engine is 3.3 -liter isuzu diesel. When placing it on the machine, Daewoo put him on the valve cover and in the auto -elevator manual it appears as Daewoo 33 dB. The identification of the injection pump is as follows.
ZEXEL
101492-0041
569R426495.
I hope this helps. Thank you.
13 years 10 months before #24998 by manual-mecanica
Give me time to see what I can do, anyway, measuring comprehension and advancing the pump a little, if Isuzu is the openwork marked in the engine each pulley faces a mark with the mark of the same pulley
