C5 cooling fan problem
13 years 10 months before #24969 by manual-mecanica
Manual-Mecanica Response on the Re: Problem with C5 cooling fan
You noticed the bulb or sensor
13 years 10 months before #24976 by manual-mecanica
I have not looked at the sensor because when I do not cut with the air conditioning, it should not be a problem of being a temperature problem, but anyway I will look at it, thanks, I will tell you if I find the solution.
13 years 10 months before #24996 by manual-mecanica
The box to which you mean is BCI the electrical unit of command, repair them but check before what we told you
