Manual Quads Honda Fourtrax Trx 250 2001
13 years 10 months before #24868 by manual-mecanica
Manual Quads Honda Fourtrax Trx 250 2001 Published by Manual-Mecanica
A pleasure in greeting them, I need to know if the exploding of the Quads Honda Trx 250 Model 2001 is equal to the 99 model (at least the rear axle), the display of 99 is already lowered, but before disarming mine I want to be sure if the exploded also corresponds to 2001, I would appreciate if someone gives me this data. Thank you so much
13 years 10 months before #24880 by manual-mecanica
Manual-Mecanica Response on the Re: Quads Honda Fourtrax Trx 250 2001 manual
The truth is that I do not know, but if you have a manual, you can disarm the start to see if it is the same, anyway it is not complicated to disassemble just look and write down what you think is important not to forget anything, you can take pictures and do your own manual, what problem does the rear axle have?
13 years 10 months before #24883 by manual-mecanica
Hi Kikemec thanks for answering, I don't know what you have, I have to disarm to see. It makes an ugly noise like Corona and Piñon are not covering the gears well, I started for the axis, that this must have gone through the breakage of some bearing, having a game makes them not fit my teeth well and that must be the noise that I hear, I hope that my teeth are not skipped because there will come out quite face to me the repair.
13 years 10 months before #24944 by manual-mecanica
Mario then starts to remove the game, if it is bearing, that the most commonly disarms the outer part you change the bearing and proof, you should have an order in the repairs if you take a crown and that and do not repair the fault itself that is to say the cause that probococus the rupture, it will happen again, if it is rolling first and proof you want it is not so expensive.
