How to disarm the flywheel of a Corsa year 2000 ??
13 years 10 months before #24712 by manual-mecanica
The problem is that I want to disassemble it to see why it sounds when you step on hollow, it has a rattling that I don't like .. someone has a tutorial of how to disarm it to check what it sounds like? Or does anyone know what does it sound, which sounds a tracheteo? Thanks .. this model also tells Chevy Pop ..
13 years 10 months before #24729 by manual-mecanica
hi how are things.
Friend, to start disassembling the driving steering wheel you must leave for the central part where the horn is located, if you do not wear screws on its back only carries enclaves that you must force up to disassemble it, then disconnect electrically the horn and find a central nut that keeps the steering wheel firm to its axis. It worries to mark the position with respect to the axis and then hit the axis pulling the steering wheel to release the conical adjustment of the steering wheel to the axis.
Tell us the advance ...
13 years 10 months before #24860 by manual-mecanica
Hello, look before disassembling the steering wheel checks the feats and terminals of the zipper
check that it does not wear or are also lazy if it is Chevy Pop the zipper should be standard if so after a while they wear out internally and you have to replace it
Neesecitas to be sure if the noise originates in the column or in the zipper or suspension.
13 years 10 months before #24876 by manual-mecanica
The direction column is very difficult for me to put some type of noise, the only part is the cardanic joint, but for this failure to spend a lot of time, unless it is changed.
