Daewoo Lanos starter problem 1.4
13 years 10 months before #24623 by manual-mecanica
Daewoo Lanos 1.4 starter problem published by Manual-Mecanica
Hello again to all the foreros, today I have had a problem in my wool, because circulating with the velocimeter needle became zero (that is, the speed did not mark me) and the light of Check was lit.
Apparent the car and stop the engine, I give it to contact and after several attempts it starts but then stops.
Gasoline arrives, I have looked at all the fuses, the spark plug wires and seem to be all right, but the engine starts and then stops.
Well waiting for your wise councils.
Greetings ………… .Jomadu
13 years 10 months before #24625 by manual-mecanica
Manual-Mecanica Response on the Re: Start Problem Daewoo Lanos 1.4
The speed sensor that goes in the box, who is the reducer that measures the veinocity, without that sensor produces that fault, it is easy to change and it is not expensive, now you can make a tmbn Scaner,
13 years 10 months before #24682 by manual-mecanica
It is correct what Jona says, you can do the scanner to be sure, but the speed sensor is check without this information, the vehicle assumes that it is in stop mode and does not inject fuel into sufficient quantity.
13 years 10 months before #24683 by manual-mecanica
It really seems to me that what you say is incorrect
and seen number of cars without those sensors and work look for damage on the other side
13 years 10 months before #24684 by manual-mecanica
Rojas Caicedo wrote: It really seems to me that what you say is incorrect
and seen number of cars without those sensors and work look for damage on the other hand
Sorry, maybe I am equiboke, but if a Chevete or a Charade G20 obviously does not affect them, the issue is that the computer is the one who governs the systems generally and if it does not receive information, for example of the oxygen sensor, it will obviously be unstable and have the gases high, likewise with the speed sensor that is that apart from going to the board, a signal goes to the computer indicates to the computer indicating data ...
