problem with F150
13 years 10 months before #24370 by manual-mecanica
problem with F150 posted by manual-mecanica
The computer is damaged and the engine and transmission is changed but when I turn on a balancing of one of the heads, it will be that the computer is affecting or perhaps another problem I thank you
13 years 10 months before #24374 by manual-mecanica
Manual-Mecanica Response on the Re: Problem with F150
Good morning, if you walk the computer and engine and transmission, and if the camvios enter, the problem is a non -electric mechanic, it has nothing to do with the computer, the balansin is probably lazy, or this vessel a bus where the flute is crowded and that the balansin puchansin, check if the cables are in order, explain better it the problem, and let me know.
13 years 10 months before #24392 by manual-mecanica
Huy really friend that I did not understand the question, try to put more information, but if what you say or the problem is of a mechanical mobile part, and not electric then discard the comp ..
13 years 10 months before #24394 by manual-mecanica
According to the information you give, the problem is mechanical
and nessites check the system of the head of the head and the valve itself, since it could be stuck and that causes the Valancin to fall, screw of the sweeping, broken balancing, broken, broken spring etc. etc
Anyway, remove the aterma and dearma lid and wash everything so
that you check that it does not help wear on the feet
13 years 10 months before #24396 by manual-mecanica
Hey would also be good to say the model and if it marks failure code, but as the friend says if it is a noise in the balance is not of the computer
