Pugot partner clutches
13 years 10 months before #24366 by manual-mecanica
Flag of Pegot Partner published by Manual-Mecanica
Hello, I have a 2005 partner, a few days ago the clutch pedal began to have a malfunction, it got off at the middle of the race and did not cut correctly, I lubricated the visible parts of the small Chicote in question, I lubricated it but when putting it I discovered that I had lost all adjustment, no longer cuts anything, it is going thoroughly and does not even move the clutch lever, and now I am with the problem that I do not know how to adjust it, because at first glance you do not see any way to adjust it, if anyone knows how, I will thank you to make it know, thank you in advance, thank you in advance.
13 years 10 months before #24369 by manual-mecanica
Manual-Mecanica Answer on the Re: Strike of Pegot Partner
Hello painter welcome to MDM, what happens are two things, the first those piolas do not have regulation automatically, when you take them you must tie them so as not to lose memory, if nothing moves you anything, nothing can have been disconnected from the pedal, to connect it again you will have to take out the clutch pedal, this is done with two wires of 13 mm, the pedal has two bolts one. Bolt, nothing difficult to do, as a recommendation I advise you, that you buy the piola with manual regulation is better, both types and normal regulation sell. They are not expensive here in Chile, about 9 thousand Chilean pesos leaves, but check first that it does not disconnected from the pedal. Let us know.
13 years 10 months before #24433 by manual-mecanica
Hello, the partner has a cable with automatic adjustment by means of two rollers that are not visibbles so if the cable fails, it changes it ... I also have to inform you that in the clutch pedal there is an adjustment for the height of the pedal that sometimes if the damage is starting you can use it. But better change ....... Here in Costa Rica there are no cables with manual adjustment ...
