Does not turn on Shadow 1993
13 years 10 months before #24268 by manual-mecanica
Does not light automatic Shadow published by Manual-Mecanica
I do not turn on my car, Shadow 1993 automatic, I already chewed the gasoline pump, it works, apparently it does not pass current to the coil that feeds the spark plugs, I already checked cables and I find nothing, I have changed the relays, and neither does it turn on!
13 years 10 months before #24270 by manual-mecanica
Manual-Mecanica Response on the Re: Does not light automatic Shadow
If what you do not have is spark, and you say that you have already changed relay, then the problem is the hall effect, which is the album that comes within the distributor, I guarantee that this is the problem
13 years 10 months before #24322 by manual-mecanica
;) thank you! I'm going to check it right away and let you know about the progress!
13 years 10 months before #24324 by manual-mecanica
And if that is not, check the change lever ._. no matter how basic that I think I suppose that if the car is not in NOP, it does not part ._.
