Carter Audi A4 1.8t problems from 98
13 years 10 months before #24256 by manual-mecanica
Carter Audi A4 1.8T problems published by Manual-Mecanica
Good wave to all I took 2 days trying to kitar the carter of an Audi A4 1.8t of 98 and does not go to change the bonba of oil, since I glimpse to make a noise like the takes and I whistled all the time the oil level the car stopped immediate
13 years 10 months before #24304 by manual-mecanica
Manual-Mecanica Response on the Re: problems Carter Audi A4 1.8t of 98
You already removed the 2 screws that go on the side of the box, and remember that you have to hang the suspension bridge to be able to take it out, in fact you have to support the entire engine and box, since you have to remove all the screws, very careful friend, since it is something risky, if you are not professional, do not risk, leave it to someone who has already done it previously
13 years 10 months before #24309 by manual-mecanica
Yesterday I finally kite it to kitar the entire front also to kitar a doport that goes on the air compressor pulley because it does not let the carter lower the truth that has a lot
13 years 10 months before #24310 by manual-mecanica
Yesterday I got it the only thing that was a little worried that the bonba did not seem broken, because of the symptoms that the car gave me everyone told me that it was the pump I hope that if, the symptoms that gave me were to maracar the oil level all the time I continuously whistle and then a sound like a little strong takes and stop immediate The blades and had somewhat folded bufff I hope I have not loaded it looked at the organ and I had almost no but some blades is Aldo Dobalditaa to have now to get one cheap. Thank you very much for your help I thank you very much.
13 years 10 months before #24348 by manual-mecanica
Well, remember that before money savings, safety is first, and the turbo, I hope there is no damage, and if you have to repair it, you must change a metallic hose of oil pressure, it is the thin tube that reaches the turbo, since being so narrow, it covers and re -damaged the turbo, and the oil pump is a very common problem in the 1.8 turbo -turbocharger. Passat, well, do not forget to put the original oil filter, if it is a generic, make sure it is the double valve, to avoid loss of oil pressure, any doubt, you can consult it with all confidence
