The PMS collector is at the rear of the gearbox, between the union of the box with the engine, between the cylinder butt and the output arrow of the differential side differential. This collector is generating type if you disconnect it and check the voltage reading between terminals 1 and 2 must give you 4V to 9V, terminal 3 is shielding to avoid parasitic noise to the signal that goes to ECU but this is put to negative mass or earth, does the engine go out or only the rpm shown fall?
