The first thing you should do is check the control sheet control module, it seems to me that it is the whole problem, you can identify the cables of being that is the last turn of the key and peel them to put a button, when you do not start you give the button and if the sheet starts it is bad, another way is with the open contact and in the starter position you have a bridge between the cables of the starter engine. Start is not very complicated.
